- Jan 5, 2014
- 952
So years ago I got a great deal on a bunch 2x4 T8 troffer lights and a truck load of drop ceiling tiles and grid material. They were free via a trade and in mostly new condition. So I got to work hanging a drop ceiling in my shop. It turned out great. I recently upgraded to LEDs in them as the T8's were getting old and dim. The lighting in the shop is just outstanding. The shop is 30x36' with ceiling at 9'. The upstairs is a loft space I use for storage. The roof is a 12/12 pitch so there is good space up there.
Now the problem to solve. I was too cheap and hated fiberglas too much to do the insulation in the ceiling first. Yes. Enjoy my stupidity.
So now I'm lucky to have this really great looking (except for the disorganization), well lit shop space that I can't heat very well. The heat goes up through the drop ceiling into the loft space like the ceiling wasn't there. I have a shop stuffed full of machines, tools, materials, various ongoing projects and junk. What ever I do I'll have all that to work around/protect.
I'm thinking I need to fix this in 2021. I thought I would either;
Scrap the drop ceiling and drywall the ceiling. Probably frame the troffers because now I have $$ tied up in the LED retrofits and they do a great job lighting.
I would probably hire this out as ceiling drywall is for people younger than me. Benefit, I gain 8 inches in ceiling height. Probably the "best" approach. This sounds
expensive though and I would rather spend on tools.
or
Try to retrofit insulation and some sort of "flow barrier" over the drop ceiling. (The center 12' of 30' width of the ceiling is decked over in the loft). So only the edges, 9 Ft., are reachable from the top side. Does the paper on insulation provide enough of a flow barrier? Some other material in addition? There are all those grid hanging wires to work around of course. This seems like it would be cheaper but a royal pita. Not sure how well it would work either.
or
Other?
What would you do?
or
or
Other?
What would you do?
