- Dec 25, 2011
- 10,516
Dual voltage 3-phase motors aren't uncommon. However, the low voltage connection would almost certainly be 208 to 230 volt and the high voltage 440 to 460. Actual 120 volts 3-phase isn't impossible to make either power or motor but I don't know that I've ever actually seen either one. Commercially available (mostly Chinese) VFD's that run off of a 120 V single phase line are normally going to output 208 to 230 V Wye connected 3-phase. Which would more than likely match the motor on the lathe unless it is wound only for 277/440 V 3-phase. How likely it is to be the latter depends mainly upon where it started life (from small machine shop to large factory). You are just going to have to look at it and find out.
