- Jun 12, 2014
- 4,817
Wish this was around previously so I wouldn't have had to make my own set-true ER40. This is the first I have seen of a Set True or Set Fine adjustment style ER40 chuck from a manufacturer, and at a reasonable price. Should be easily to use different style back plates. Also see they now offer ER bearing nuts, although do not know the quality. FYI.
http://www.shars.com/5-er40-zero-set-fine-adjustment-collet-chuck
http://www.shars.com/er-40-ball-bearing-collet-nut
Works best on light cutting operation with easy to cut material such as aluminum or alloy steel
4 Fine adjustment screws on the side can be used to true up the chuck within 0.00005“ TIR repeatability
Collet chuck body is made from forged steel and precision machined
Compatible with standard ER40 collet which has a range of 1/8" to 1"
Max 6,000 rpm
Comes with 3 mounting bolts M8 x 70mm
Offer in plain back mounting with various threads size back plate or D series direct camlock mounting
Max 6,000 rpm
