- Dec 21, 2018
- 1,822
I have a Shares tool & cutter grinder and have sharpened some lathe inserts successfully. (Good enough for me, not back to factory!) It changes the geometry and to some extent the affect of the chip breaker design. The result has been a sharper edge that likely will dull quicker than the eased edges that are normal. An advantage is less pressure on the work and finer passes allowed. If it was for CNC work the tooling would need to be recalibrated for each insert change, but not for my manual use.
With careful setup I can get fairly consistent nose radii. There is some flex in the tool grinder so it isn't "dead on." But very close. I'm quite slow at getting a good setup so I don't do it until I accumulate several inserts.
I have a shell milling cutter that uses inserts that have only two usable cutting edges. I haven't tried regrinding them, yet. I'll have to make a holder for them to mount on the grinder. I'm less than convinced I can get all inserts exactly/close enough to produce a factory quality cut. At the price of name brand inserts I'm willing to take the time to give it a try. Obviously the coating is lost but for my use it really doesn't matter all that much.
Have any of you done this? What methods did you use to get good results, if you did?
