Shaper Tool Mods with Ulma Doctor
Ulma Doctor
Infinitely Curious
Active Member
Feb 2, 2013
4,294
Likes
3,483
#4
Mike , looking at the video and listening to the ratchet sound, I am thinking you are advancing the tool on the cutting stroke not the return stroke.
Thank you very much Doubleeboy, you were 100% correct-
it was feeding in the forward stroke!!!
i didn't even consider which way was correct, it was in the same position as when i got it.
i just went out and reversed the feed and locked 'er down- now the box advances on the return stroke :grin:
i really appreciate the heads up,
thank you good sir! :tranquility:
Ulma Doctor
Infinitely Curious
Active Member
Feb 2, 2013
4,294
Likes
3,483
#5
i have one other piece of the puzzle that may be part of the mystery.
when i bought the shaper,
the PO had a bit in the toolpost with the business end oriented like he was using the pull stroke.
could it be possible that he had the feed reversed to complement using the pull stroke???
or am i reaching for a conclusion to justify my ignorance? o_O
Bob Korves
H-M Supporter - Premium Member
H-M Supporter-Premium Member
Jul 2, 2014
4,024
Likes
4,172
#6
Was there a reverse clapper like Stefan uses or clapper lockout when you got the shaper, Mike?
Ulma Doctor
Infinitely Curious
Active Member
Feb 2, 2013
4,294
Likes
3,483
#7
nope :confusion:
my ignorance is now justified!!! :grin big:
all i can conclude now is that the tool was in backward, maybe hastily, to keep the toolholer in place.
and the shaper was feeding on the push stroke :frown 2:
i can't let that stop the show!
so i got the situation rectified and did some more shapin'
the surface finish is great!!!
and it now fits the toolholder.!
some more video coming soon!
f350ca
Active Member
Jul 11, 2013
1,179
Likes
1,832
#8
I think I've heard of cutting on the pull stroke when doing key ways. And then it was cutting on the top of the bore. Haven't tried it.
Greg
Doubleeboy
Active Member
Dec 3, 2014
623
Likes
328
#9
I am no expert on shapers but I do own one and use it semi regularly. I can on my Logan 8" set the table to advance on push or pull stroke, but I can not change which one is faster, it will always move faster on return stroke. I have never operated an Ammco, but they look nice and are well regarded. Looks like Mike is getting some pretty good surface finish. The other day I took a 1/4" lathe tool sharpened roughly to Mikey's lathe tool specs and put it in my shaper and made very nice little 9 shaped chips, with a smile on my face. Eventually I would like to get set up with dividing head on shaper and make internal tooth gear wheels, but I suspect that is a ways away. I will be following Mike's shaper threads.
michael
Doubleeboy
Active Member
Dec 3, 2014
623
Likes
328
#10
I have mistakenly feed on the forward stroke , you can get away with it sometimes but if you get in tough to machine steel and the cut gets progressively larger as stroke continues you can get into trouble real quick. On a little shaper I want everything singing like a sewing machine, seems like all the little machines were built to a price point and there are weak links, I sure don't want to bust one up for some foolish move. In my experience on the few machines I have been around while operating you want to hear the ratchet sound on forward stroke and the silence on return stroke. When machine is running fast sometimes its hard to differentiate. To ease my confused state I have taken a dial indicator on a Noga holder and set up to see table advancement to make sure I got it right.
cheers
michael
Ulma Doctor
Infinitely Curious
Active Member
Feb 2, 2013
4,294
Likes
3,483
#11
cheers
michael
thank you very much for the information and your recommendation.
your help dramatically improved the surface finish. :eagerness:
Greg
Thanks Greg, for reading and commenting- i haven't tried it either :courage:
maybe an upcoming project???
i saw stefan gotswinter on youtube using the pull stroke, but as Bob korves mentioned earlier.
the clapper is hinged at the bottom,
instead of at the (conventional) top of the clapper, when you use the pull stroke.
Ulma Doctor
Infinitely Curious
Active Member
Feb 2, 2013
4,294
Likes
3,483
#12
here is a video of the final finish cuts on the carbide lathe tool mod
i spared the audience the sound of my voice and let the shaper do the talking
enjoy!
the operation was a success and the patient lived!
f350ca
Active Member
Jul 11, 2013
1,179
Likes
1,832
#13
Nice surface finish. Wish mine ran that quiet. The reeves drive in the Logan I had was noisy, and the Peerless has a LOT of gear noise and an intermittent knock I think coming from the linkage below the arm driving the ram.
Greg
Ulma Doctor
Infinitely Curious
Active Member
Feb 2, 2013
4,294
Likes
3,483
#14
Greg
thank you Greg.:grin:
she is beautiful music to my ears!
have you tried thicker oils for lubricating the knocking areas?
the original wood cabinet that my shaper came on has long since deteriorated.
the only remnant is the top that the shaper is bolted to.
i really need to replace the wood.
the shaper is setting on a nice frame, but i really need to replace the wood.
i have considered some red oak planks with a substantial plywood top.
Bob Korves
Jul 2, 2014
4,024
Likes
4,172
#15
Nice, Mike! Looks like you are getting the hang of the shaper and what it needs to do good work. Smooth, quiet, and under control...
Ulma Doctor
Infinitely Curious
Active Member
Feb 2, 2013
4,294
Likes
3,483
#17
thank you Bob
It sure is fun to play with!
Very nice Mike. Keep up good work. You're shortening my learning curve :)
Ted
Hi Ted,
We can all learn from my ignorance and mistakes!
Silverbullet
Active Member
Active Member
May 4, 2015
2,347
Likes
1,055
#18
Cutting across the face can be done in both directions if the tool is ground correctly. When using the pull motion the clapper usually is reversed or locked. Mostly it can do almost any type cut . Even gears can be cut , splines , internal and exterior. One of the most under used tools in many years.. I use to love cutting vise jaw grips. The points were real points not nubs.
Container Above bottom breadcrumb
