- Jun 7, 2013
- 10,101
I have seen keyseating tools for shapers, homemade, that replace the tool post; at the front end they are threaded for a nut that retains them and clamps them in place; they are necked down to whatever diameter and length is appropriate for the job at hand and provided with a square hole near the outer end and the end is drilled and tapped for a setscrew. This said, I have never been a fan of keyseating in the shaper, what with the tool dragging on the return stroke and dulling easily, lots of chatter, etc. One thing to remember; do your cutting on the top side of the workpiece, not the bottom, this eliminates the chance of the tool dropping down while feeding into the cut. Also of course, the clapper box must be immobilized, usually with setscrews near the bottom on one or both sides that bear on dimples drilled into the clapper; most shapers that I have seen and used, already have these provided, my 20-24 Gould & Eberhardt does, but thanks be, I do not have to use it for internal shaping, as I also have a 6" Pratt & Whitney vertical shaper for that class of work; it has a specially designed clapper box that makes internal shaping a pleasure so far as tooling holding up is concerned. One thing about internal shaping tools is that very little relief (clearance) on the cutting face is required, only a few degrees, and back rake should not be excessive, or the tools tend to hog in.
