While the Lewis shaper was advertised as a 10" shaper, you will find it only strokes about 9.5", which makes it an 8" shaper (they always stroke a bit longer than their spec size, in order to allow the run in and out to cut something that size). I believe that Atlas recommended a 1/3 hp motor for their 7 inch shaper, and I would think anything in the 1/3 to 1/2 hp range would be fine. 3/4 hp is probably overkill for this shaper, as you will likely break something in your setup, or the tool before you bog the motor. If you are looking for useable speed ranges, I would recommend something like 50-150 SPM. More than 150 SPM starts to get scary. The actual cutting speed is dependent on the length of stroke as well as the strokes per minute (you need to run higher SPM for shorter strokes to the same surface speed as a longer stroke at a lower SPM). The calculation is in Moltrechts 2nd Machine Shop Practice, and works out to S=7.2V/L, where S is SPM, V is the cutting speed in FPM, and L is the length of the stroke in inches. The constant accounts for the non cutting time and the unit conversion from ft to in. The table in that book shows cutting speeds ranging from 25 for hard alloy steel to 140 for brass. So using a cutting speed of 110 FPM (mild steel) and a stroke of 8" gives SPM of 99. Changing the stroke down to 5.5 inches with the same material gives 144 SPM. One thing about planers and shapers is that they usually can't achieve the high cutting speeds that you would ideally use for aluminum or other soft materials. Enjoy the shaper.
