- Mar 5, 2019
- 216
i may order a couple, but since i hate waiting i made one. i feel pretty confident i have the sides parallel.
I guess that it all depends on the amount of step-over that is used, I like to take about half the wheel width with the Thompson, less with the micromaster, with minimal step over you could take .005, but I think it would cause excelerated wheel wear on the corners of the wheel.I'm surprised that the Thompson had a hard time with cuts of .005". We had a similar size Thompson at work and routinely did roughing passes of .005". Over the years I've used a number of different brands of grinders including Kent, K O Lee, Harig, and Brown & Sharpe. Most used 1/2" or 3/4" wheels and easily removed .005" per pass.
My little Sanford 612 will easily remove .005 per pass with 1/4" and 1/2" wheels, and it's only 1/3 hp. The machine will take up to a 3/4" wheel, but even then the step over is .100" or less per pass, so there's really no advantage to using a wider wheel. The most common wheels I use are 46 G, H, or J. These are the ones that will easily remove .005" on a rough cut. I don't think I would try to cut that much using 80, 100, or 120 wheels in that the wheels would wear down to nothing in short order.
Awesome,Update and additional questions..
So at this point i have made several arbors, all left hand thread and they seem to work well. i have been practicing my surface grinding and while i have a long way to go i really like it.
I have made a wheel balancing arbor and I've tried to balance my wheels. the smaller, 1/4" diameter, wheels i can get pretty well balanced by drilling out pockets on the side, but my main wheel is a larger 1" diameter wheel that i cannot seem to get balanced .. so onto building a balancing ring like I've seen several youtube experts do where make a ring with a bunch of threaded holes and screw in set screws until its balanced.. So my question:
is there any reason i cannot take the actual arbor and put the threaded holes in it, fill them with the set screws to balance?
