- Feb 1, 2015
- 9,621
Keith, yes it sounds like you did it right. The .250" is a smoking gun. Did you measure with calipers or did you use the DRO with an edge finder?
The practice of measuring outside to outside of a pair of bolts and subtracting the diameter of the bolt should get you much closer. The error arises because on clearance between the bolt and threaded hole tilting the bolts slightly so the measured distance is slightly short (To compensate for this, I try to run short socket head cap screws instead and measure the head diameter and the outside to outside of the heads).
I have a pair of HF calipers that will add .200" to the reading for no reason that I can see. I don't use them for that reason. If your calipers do that trick, check the zero setting. I have never seen them reset so if the zero is off, reset and remeasure.If you measured with calipers, that could be an issue. I have a set of cheap calipers that, for whatever reason, sometimes "skip" counts and I end up with a grossly inaccurate number. They usually give me dead-on accuracy or left-field dimensions. I only use them for rough measurements and still double check with a scale.
