When I set up a workpiece on parallels, and then tighten the vise, the parallels are loose enough to slide out. I can sometimes beat this by getting the jaws snug, but not tight, and tapping the work with a nylon faced hammer, and then finishing the clamping.
Is this normal? Is it a sign of out-of-parallel jaws? It's an old 3" vise that fits nicely on my Rockwell mill. Do the parallels need to remain tight under the workpiece, or am I too concerned about a non-issue?
Something you may want to try is using a lead hammer. In the old days, the shops had copper, brass, lead, and rubber hammers.
Don't be fooled into buying a cheap dead blow hammer,:nono: if you are trying to achieve production run, repeatability.
To be very precise, the workpiece should be touching the parallels at all surface edges.
Something else you may want to check...indicate in the bottom rails of your vise, to check for flatness. If that's out, your parallels won't seat accurately.
