- Nov 9, 2013
- 790
I have a L-W dividing head that looks identical to the one Nels has. It's my first attempt to cut a spur gear, and I've gone through everything very carefully to make sure there are no mistakes. The gear I'm cutting is made of cast iron and will have 37 teeth, and I have a dividing plate with 37 holes in it.
The question: Because my dividing head has a 40:1 ratio, I should turn the crank less than one full turn to advance to the next tooth? Or, because I have a 37 hole plate, do I just do a full turn?
Up to now all my measurements have been careful and correct. The perfect gear blank, centering the cutter, depth of cut, etc. The more I thought about this, the more I confused myself. I just want to make sure I don't make scrap iron.
Thank you!
GG
Thank you!
GG
