Servo 140 limit switch wiring diagram...
FOMOGO
Sep 2, 2013
5,131
Have been going through Servo 140 power feed on my Acra mill. Replaced the power switch, and adjusted the rapid switch so the unit now functions as it should, but no joy on the limit switch. It has four wires red,white, black, and blue, with the blue having been cut at the switch. Does anyone have a schematic for the switch, or possibly take the cover off their limit switch and let me know how it's wired. Thanks, Mike
Those are Micro switches- they should be marked as to the contacts:
normally open or NO
normally closed or NC
and common or Com
No, wasn't working at all until I replaced the power switch, then no stop function at the limit switch. Mike
I don't see the little "leafs" or actuator arms on the switches- Need to see a shot in the box
to see how the plunger mechanism works- maybe a very early model or pieces could be missing
Looks like you might need to rebuild the limit switch box or replace it- they are available on Ebay
That diagram doesn't seem to show the limit switch wiring- if it does my pea-brain can't follow it LOL
You're right Mark, that's my screwup. Thought it was in the diagrams in the upper right, but it just shows one of the leads coming from the limit switch, not the limit switch itself. Apologies.
No need to apologize- I wonder if they had a separate schematic for the limit switch?
Or if it is indeed the two switches in the upper right hand side of the upper diagram? If so it's not very clear
