- Apr 29, 2019
- 2,071
OK so the LED has the ~1K ohm resistor built in, that makes it easier. You will still need a resistor that is the same resistance as the bulb would be so that the computer sees the correct current. You could add a bulb in parallel with the LED but be forwarned that if that bulb does burn out, you will be pulling hair trying to figure out what is wrong. resistors are pretty much good forever.
I just spent 6 months chasing an intermitent P0650 code that was preventing me from getting plates. Unfortunately I learned a lot about the system in the process.
