- Nov 13, 2013
- 104
Hello
I picked up a rather neglected 9A. Everything from the gears, quick change gear box and apron were filled/packed with grease and particulate (twas a mess)
Disassembled, cleaned with kerosene and reassembled. I've acquired all of the recommended oils and lubes. All good so far.
Even after looking at the lube chart I am still confused.........My question is,
what lubricant is applied externally (topically) to the dry gears and internals of the apron?
Thank you again
Thank you again
