- Jan 1, 2014
- 233
Have always been annoyed with the cross-slide chip guard on my SB 10" because to move the cross-slide fully away (aft) you need to turn that chip guard around because it runs into the base of the compound rest, and, you have to back things off to be able to get enough room to swing the guard around. When you again move the cross-slide forward the lead screw becomes exposed so you must once again turn the guard around. So I made a stacked double leaf replacement which gets rid of that issue. The two leaves are basically the same except the slot in the under leaf is about half-travel length, this causes the under leaf to get picked up by the locking bolt about halfway during back travel, and, if already back, the locking bolt again picks up the under leaf about halfway during forward travel. The narrow slots at the back are just to keep the leaves aligned and ride against a small screw at the back. At no time is the cross slide lead-screw exposed. I had already made a different and longer extension arm to accommodate the DRO out back so had territory to mount the extra length of the new leaves.
Hope you find this interesting.
