- Apr 14, 2014
- 3,152
Thank you everyone for your input. My experience with my 10" Dewalt RAS is similar to Mike's experience with his 10" Delta. At the time when these saws were new there wasn't much talk about tooth hook or grind profile. I have over a dozen blades for this saw and none of them state either the type of grind or the amount of hook.
Keep in mind my Dewalt saw was purchased years before carbide tipped blades came on the market. When carbide tips started becoming popular HSS and carbon steel blades were all but being given away. The thought was that the new style was going to replace every non-carbide blade in the world. They may have worked fine in some situations, but I quickly found out they weren't the best for my particular saw. At that point in time there were 2 limiting factors for their use. First off, the hp of the saws were overrated. The Dewalt 740 supposedly develops 2 hp. In reality it's closer to 1 or 1 1/2. Secondly the original carbide tipped blades all had an 1/8" kerf as compared to the 1/16" kerf of a plain steel blade. The combination of lack of power and wide kerf blades were tough on the saw. In one summer I went through 2 overloads trying to cut treated lumber for a deck.
The manual for the Dewalt saw recommends setting the roller head bearings tight enough to the rails that it takes 6 psi to pull the head across the table. I'm guessing this is done to minimize the self-feeding effect of positive hook blades. The Delta saw manual doesn't specify any amount of pressure needed to advance the head. It also has a cutting head return mechanism that retracts the cutting head when the handle is released.
In days past blade grind technology for consumer-oriented saws was all but nonexistent. There were different blades for ripping and cross cutting, but the differences were mainly number of teeth, and depth of the gullets.
Fast forward 50 years and blade technology has changed drastically. We're talking a number of tooth grinds from ATB to TCG, ATBR, HATB, ATAFR, and who knows what else. Hook angles (rake) vary from -5* to +20* and possibly more. Different types of saws require different blades for different materials. The one notable thing is that most blade manufacturers recommend negative hook blades for radial arm saws, and positive hook blades for table saws. The newer technology enhances the performance of older or under powered saws. It also allows most any saw to make precise flawless cuts in nearly any material.
Having said all this, I think I'll give one of the new blades a try next weekend. At this point the only thing that needs to be done is crosscutting more decking boards to length. If the current blades don't give a satisfactory cut there will be a couple Freud Ultimate cutoff blades (LU85RO14) on the short list of blades to buy. I'll also consider a couple heavy duty Freud glue line ripping blades (LM72MO14). The reason I mention purchasing 2 of each style blade is that quality sharpening businesses are all but nonexistent in the immediate area. The blades will have to be shipped to a sharpener, which usually takes a week or more depending on their workload. I'd hate to be down for a week or more due to a dull saw blade.
Thanks again everyone!
