- Sep 8, 2019
- 4,392
So one thing that did *not* work was using the 40 grit on the orbital sander to flatten the material. I was doing this because I am running low on 50 grit belts, but I will just buy more 50 grit sanding belts because the belt sander does a great job of getting the material flat! When it is doing this, it sort of skates over the material (on the high spots).
Here is a picture of the belt sander exposing the parts that are not flat.
Once the material is completely flat, the belt sander is a beast. It is the perfect power level for this job.
Here is a picture of the material down to 50 grit from the belt sander. Here we are very happy that it is flat.
I’ve only seen that they sell the 3” X 18” sanding belts in 50, 80 and 120 grits, so I am sure that I will use the belt sander to get everything down to 120 grit since it does such a fantastic job.
*I sure am lucky that you guys recommended the belt sander*, and that my dad had one for me to borrow.
