Sand Blasting Cabinet Lights
Paul thats right, glass beads dont hurt bulbs or use those thick glass flood lights. If you read my other
post about leaving a drop light in there that ended the dampness. Thats an old welders trick in the
shop with an old refridge with a 60watt bulb keeping welding rods dry.
GK my shop is climate controlled so the shouldn't be a problem with moisture. And I'm a OLD welder:)rofl:) so I used the fridge untill I got a rod box.
I don't weld much anymore but I still have a box full of rods if I do I use my MM251.
Paul
