    Dismiss Notice
Safety Warning: Working With Electricity -- PLEASE READ!!
Discussion in 'ELECTRICAL ISSUES - POWER YOUR MACHINES & SHOP' started by Management, Feb 18, 2013.
Thread Status:
Not open for further replies.
  1. Management
    Management United States Administrator Staff Member Administrator
    81
    28
    -Return to Top-
    Disclaimer:
    Electricity is inherently dangerous. It will kill you and burn down your house and everything you own if you fail to pay it the proper respect. If you don't feel competent to work with it, don't. Call an electrical engineer, electrician, or someone down the street who knows what he's doing. Stop. Take a step back. Think. And if you're using electrical tape you're already doing it wrong.
    Electrical Hazards
    The major hazards associated with electricity are electrical shock and fire. Electrical shock occurs when the body becomes part of the electric circuit, either when an individual comes in contact with both wires of an electrical circuit, one wire of an energized circuit and the ground, or a metallic part that has become energized by contact with an electrical conductor.
    The severity and effects of an electrical shock depend on a number of factors, such as the pathway through the body, the amount of current, the length of time of the exposure, and whether the skin is wet or dry. Water is a great conductor of electricity, allowing current to flow more easily in wet conditions and through wet skin. The effect of the shock may range from a slight tingle to severe burns to cardiac arrest. The chart below shows the general relationship between the degree of injury and amount of current for a 60-cycle hand-to-foot path of one second's duration of shock. While reading this chart, keep in mind that most electrical circuits can provide, under normal conditions, up to 20,000 milliamperes of current flow.
    In addition to the electrical shock hazards, sparks from electrical equipment can serve as an ignition source for flammable or explosive vapors.
    Even loss of electrical power can result in extremely hazardous situations. Flammable or toxic vapors may be released as a chemical warms when a refrigerator or freezer fails. Fume hoods may cease to operate, allowing vapors to be released into the work area. If magnetic or mechanical stirrers fail to operate, safe mixing of reagents may be compromised.
    Preventing Electrical Hazards
    There are various ways of protecting people from the hazards caused by electricity, including insulation, guarding, grounding, and electrical protective devices. Workers can significantly reduce electrical hazards by following some basic precautions:
    Inspect wiring of equipment before each use. Replace damaged or frayed electrical cords immediately.
    Use safe work practices every time electrical equipment is used.
    Know the location and how to operate shut-off switches and/or circuit breaker panels. Use these devices to shut off equipment in the event of a fire or electrocution.
    Limit the use of extension cords. Use only for temporary operations. In all other cases, request installation of a new electrical outlet.
    Use only multi-plug adapters equipped with circuit breakers or fuses.
    Place exposed electrical conductors (such as those sometimes used with electrophoresis devices) behind Plexiglas shields.
    Minimize the potential for water or chemical spills on or near electrical equipment.
    Insulation
    All electrical cords should have sufficient insulation to prevent direct contact with wires. It is particularly important to check all cords before each use, since corrosive chemicals or solvent vapors may erode the insulation.
    Damaged cords should be repaired or taken out of service immediately, especially in wet environments such as cold rooms and near water baths.
    Guarding
    Live parts of electric equipment operating at 50 volts or more (i.e., electrophoresis devices) must be guarded against accidental contact. Plexiglas shields may be used to protect against exposed live parts.
    Grounding
    Only equipment with three-prong plugs should be used. The third prong provides a path to ground that helps prevent the buildup of voltages that may result in an electrical shock or spark. This does not guarantee that no one will receive a shock, be injured, or be killed. It will, however, substantially reduce the possibility of such accidents, especially when used in combination with other safety measures.
    Circuit Protection Devices
    Circuit protection devices are designed to automatically limit or shut off the flow of electricity in the event of a ground-fault, overload, or short circuit in the wiring system. Fuses, circuit breakers, and ground-fault circuit interrupters are three well-known examples of such devices.
    Fuses and circuit breakers prevent over-heating of wires and components that might otherwise create hazards for operators. They disconnect the circuit when it becomes overloaded. This overload protection is very useful for equipment that is left on for extended periods of time, such as stirrers, vacuum pumps, drying ovens, Variacs and other electrical equipment.
    The ground-fault circuit interrupter, or GFCI, is designed to shutoff electric power if a ground fault is detected. The GFCI is particularly useful near sinks and wet locations. Since GFCIs can cause equipment to shutdown unexpectedly, they may not be appropriate for certain apparatus. Portable GFCI adapters (available in most safety supply catalogs) may be used with a non-GFCI outlet.
    Motors
    In areas where volatile flammable materials are used, motor-driven electrical equipment should be equipped with non-sparking induction motors or air motors. Avoid series-wound motors, such as those generally found in vacuum pumps, rotary evaporators and stirrers. Series-wound motors are also usually found in household appliances such as blenders, mixers, vacuum cleaners and power drills. These appliances should not be used unless flammable vapors are adequately controlled.
    Safe Work Practices
    The following practices may reduce risk of injury or fire when working with electrical equipment:
    Avoid contact with energized electrical circuits.
    Disconnect the power source before servicing or repairing electrical equipment.
    When it is necessary to handle equipment that is plugged in, be sure hands are dry and, when possible, wear nonconductive gloves and shoes with insulated soles.
    If it is not unsafe to do so, work with only one hand, keeping the other hand at your side or in your pocket, away from all conductive material. This precaution reduces the likelihood of accidents that result in current passing through the chest cavity.
    Minimize the use of electrical equipment in cold rooms or other areas where condensation is likely. If equipment must be used in such areas, mount the equipment on a wall or vertical panel.
    If water or a chemical is spilled onto equipment, shut off power at the main switch or circuit breaker and unplug the equipment.
    If an individual comes in contact with a live electrical conductor, do not touch the equipment, cord or person. Disconnect the power source from the circuit breaker or pull out the plug using a leather belt.
    High Voltage or Current
    Repairs of high voltage or high current equipment should be performed by trained electricians. Individuals who are experienced in such tasks and would like to perform such work on their own equipment must first receive specialized electrical safety related work practices training by EHS staff. Contact the University Safety Engineer, Greg Cantrell, at 258-5849 for more information.
    The following additional precautions should be taken:
    Always assume a high voltage potential exists within a device while servicing it, even if it is de-energized and disconnected from its power source.
    Avoid becoming grounded by staying at least 6 inches away from walls, water, and all metal materials, including pipes.
    Use voltmeters and test equipment with ratings and leads sufficient to measure the highest potential voltage expected to be found inside the equipment being serviced.
    After servicing, check equipment with a multimeter or appropriate device to ensure it is grounded before reconnecting to the power source.
    WORKING SAFELY AROUND ELECTRICITY
    Industry runs on electricity. It’s safe to use when you know what you’re doing and take proper precautions. When precautions are not taken, electricity can be a killer.
    How you are affected by electric shock depends on the following factors
    The rate the current flows through your body. This depends on how good your body conducts electricity. If you have dry hands and are standing on a non-conductive surface such as a rubber mat, you may not even feel a shock. If you are perspiring and are standing in water, you could be killed.
    The length of time the current flows through your body. The longer the electric contact, the greater the current flow and the greater the shock
    The path the current takes through your body. The most dangerous path is through vital organs.
    Your actions can protect your safety.
    Read and follow instructions before handling anything electrical. If you don’t understand the instructions, get qualified help-don’t guess.
    Plugs should only be inserted in receptacle outlets with the same slot or blade pattern, unless proper adapters are used. Don’t force or alter a plug by bending, twisting or removing blades to make it fit into a receptacle outlet.
    Water conducts electricity. Keep wet hands from touching electrical equipment or light switches.
    Firmly grip the plug, not the cord, when disconnecting equipment. Yanking the cord can damage the cord, plug, or receptacle outlet and result in a shock or fire
    Because electricity is present even when the switch is in the "off" position, unplug equipment, appliances and extension cords when not in use and before inspecting, cleaning, or fixing them
    Recognize signs of overloaded circuits including flickering or dimming lights, blown fuses, warm wall plates or extension cords, and tripped circuit breakers
    Receptacle outlets and switches should not be painted or covered with wallpaper paste.
    There’s no margin for error when working with electricity. Conditions vary so much that without the facts, you may make a mistake and cause injury to yourself or fellow workers.
    The above evaluations and/or recommendations are for general guidance only and should not be relied upon for legal compliance purposes. They are based solely on the information provided to us and relate only to those conditions specifically discussed. We do not make any warranty, expressed or implied, that your workplace is safe or healthful or that it complies with all laws, regulations or standards.
Thread Status:
Share This Page
