- Dec 3, 2017
- 1,911
Any progress here?
Not sure if this is helpful at all, but my machine sits on crappy basement concrete, and it moves all the time, according to the weather and precipitation. Could that be a contributing factor in your case?
I don't know much, but this shifted head stock thing seems like the most remote of possibilities in my uneducated and inexperienced mind. But something is definitely very solidly misplaced...otherwise where would the repeatability come from? Imagine a chip embedded in the rear way. As the saddle moved across it, if the chip stayed put, the saddle would cant less and less as more of the saddle had moved past it. Or imagine the path of a flat plate with one dowel underneath it. The leading edge would climb for a certain distance, and then fall for a certain distance. Each time you rolled the plate, it would travel along the same line...Like a teeter totter with a moving hinge point. Anyways, I obviously don't know the answer, but maybe this little imagination exercise would be useful. HA!
