- Dec 20, 2012
- 9,422
Neal, to address your question about rusting, you are dealing with flash rust because your process has removed all traces of oil and surface oxides from the parts. This is commonly seen after de-rusting and is almost guaranteed after electrolysis (which I use a lot and am a big fan of).
For an Albrecht chuck, only the spindle (leadscrew thing) and threaded area of the body must be oil-free. In fact, only the spindle threads and the threads inside the body have to be oil-free. If you wish, you can apply a coat of paste wax to any other nearby surface adjacent to the threads and not cause problems and that will stop rust for some time. Just don't get anything on the threads of the spindle.
The rest of the chuck can be oiled lightly. Apply your oil of choice to discourage the rust, then wipe it all off with a rag. Enough oil will remain on the surface to discourage further rust on the innards. Assemble the chuck and use a light coat of oil on the outside and the chuck will be fine. I use Camellia Oil on the outside and have no rust issues, even though I live a mile from the ocean.
Okay, back to the etching vs non-etching debate!
