- Apr 23, 2018
- 6,541
Here, let me help you some more.This sort of positive information, in no way, helps my bank account!
https://www.ebay.com/str/tokartools
Where I worked, we called it the Floor to Keyboard Interface.“PBKAC” (problem between keyboard and chair”).
My first use planned is for setup. I'm going to be adding a taper attachment to one of my lathes and the instructions call for putting a straight edge across the ways and using a depth micrometer from a straight edge down to the taper slide bar. Measure at the front, measure at the rear and adjust as necessary to get the slide bar parallel to the ways. After it's locked in place drill and pin it.It seems cheap enough to take a risk.
I've never used a straight edge with a relieved area in the middle like that. Seems useful for setup work and inspection, but I don't think you can use it easily as a reference for bluing something up prior to scraping.
I'm curious how you are intending to use it?
Preach!I'm an absolute novice when it comes to Metrology, but I find the more I delve into it, the more I enjoy it.
The razor edge is on purpose, but not for what you may be thinking.I bought a "strait edge" from one of those countries a couple of years ago, Ebay. Not great description. Came fairly quick. It turned out to be some sort of razor sharp cutting blade, I am guessing a huge wood planer. It took a bit of back and forth but I eventually got my money back and they did not want it returned.
