- Dec 2, 2016
- 245
Is their a way to calculate the voltage you would get off the third leg without being connected to a load? I picked up a RPC from a junkyard that had the box ripped off and 8/10 caps were bad.
I replaced the caps and fire it up and was able to measure the third leg at a higher voltage. Just wondering what that voltage would be +/-
Also what would cause the caps to go bad like that, a power surge? They tops were bent outwards like all electrolytic caps are when they sh*t the bed.
The supplied voltage is 220 and its a 20HP motor.
Thanks
Thanks
