- Nov 9, 2013
- 146
After moving my rpc enclosure from a temporary spot in the shop to a permanent wall mount, I now have 220v on the phantom leg.
My rpc is basically WNY components built into a static converter running a 15hp Baldlor idler motor. It worked well enough , 118v on 2 legs and 126v on the phantom leg. Until..
This year I added a 3 ph cb panel and a motor controller for the compressor and the 3 ph floater line.
Full disclosure, this is my fault. I needed to move the components in the rpc enclosure to the opposite sides to match feed side of the power and wanted to tidy things up a bit. I wasn’t careful enough and ended up leaving a wire on the wrong side of the 1 phase power contractors. It ended up welding the power contractors closed. I replaced both the 1 and the 3ph contractors. Everything seems to work normally but now there is 220v on the phantom rather than the previous 126.
Obviously the phases are combining somewhere.
Switching legs of the idler circuit and the high 220v stays on the phantom side.
Removing all the idler wires and energizing the rpc circuit results in approximately 118v on all three legs
Is it possible that the potentiometer is permanently fixed at a point high enough to yield 220v?
Sorry I don’t have the schematics or pics here today I can add them tomorrow.
h
h
