- Feb 2, 2014
- 1,068
Well into every life a little rain must fall
I made a new piston from aluminum with an o-ring seal.
The old and the new.
The engine ran much better with very little blow by. I was adjusting the carb, valve timing, ignition timing and fly weight springs and I was getting the speed down to almost where I wanted it when KURPUT. No running, no firing, no popping and no spark. The ignition module decided to go south just like that. I checked all the connections and the battery power but no joy.
It is dead!
This is the same module that I use in my other two engines and they are running fine but not in Royal Blue.
I did find a place in Orlando that has some modules so I will be making a road trip in the near future.
to be continued
Thanks for looking
Ray
It is dead!
to be continued
Thanks for looking
Ray
