- May 27, 2016
- 3,469
Perhaps this YouTube video has been discussed here before, but I am new to this.
From the beginning, what I see is various G-Clamps and parts of cross-slide in an adventurous arrangement.
The grind seems to be a back-and forth move with no obvious spark-out. He just reverses direction at the headstock end. No advance on the grind depth, no diamond true on the wheel, and at one stage, checking out the surface, and what I see is not quite a finish ground surface..
The main thing, for me, is not understanding what surface he is using to guide the whole thing.
Beyond what I learned in school, I know very little about what to do with lathe ways, but my instincts tell me that the original unworn surfaces have alignments that are precious things. These are to be cut away to get below the worn parts.
I am not sure what we see done is a novel low cost trick to fix up a lathe way, or a real bad idea!
Can anyone help decode what is going on?
