- Sep 10, 2020
- 34
The pulley bearings are installed and in the photo is my version of the bearing lock nut wrench to tighten it all together. This is a simple 1 1/4" cast iron pipe coupler machined down to size. It isn't a hardened socket or anything and I wondered if the cast iron would crack under load, but it worked nicely. Those expensive 2 pairs of duplex bearings were class ABEC 7 and the upper spindle bearing MRC R16FF is ABEC 1. I don't recall seeing any other options on that bearing when I ordered.
What the items are sitting on in the photo is a blank canvas as they say. It is aluminum 9" wide and 10" long by 3/4" thick, marked up and ready go. This will be the foundation of the pulley housing. If my vision works out, it will be quite distinctive.
