I have chance to purchase a Rockford MV100 mill. I can find VERY little info in it. Am I taking a chance on buying something with so little information available? Parts? See a pic of one here.
http://inv.nationalmachy.com/q/webinv/005700=p,4652,,,p,,,20167540,a
OR the Hedwick variant shown in this thread. Logan apparently used the same model in their lineup.
Belts:
Motor to Vari-Drive: RVS-308 Motion Industries p/n 00689798, Gates 1626V384
Vari-Drive to Spindle Shaft: RVS-397 Motion Ind. p/n 00689861, Gates 1626V658
Spindle Drive Belt: 225L100 (22.5 OD x 1.00 wide x .375 pitch)
McM-C p/n 6484k348
Power Quill feed belt: Still working on it. (_____ x 0.50 wide x .375 pitch)
Power Quill feed belt: 150L050 (15 OD x .5 wide x .375 pitch
McM-C p/n 6484k145
Lower spindle oil seal: SKF 18159; (2.754 OD x 1.813 shaft size x .313 thick) The seal I replaced was .490 thick, but was for a 1.843 shaft size, which is why it sprayed oil when the machine was turned on. I couldn't find a seal for a 1.813 shaft size with a 2.754 OD that was around 1/2" thick, but the one I found works fine. (No more oil baths!)
Belts:
McM-C p/n 6484k348
McM-C p/n 6484k145
