The conventional method of tramming, i.e. an offset indicator sweeping the table is the most sensitive method. There is an assumption that the table surface is flat and parallel to the ways which is not always true. A simple test will determine if it is true. Mount a DTI in the spindle and lock the spindle. sweep the table in the x and the y directions and note the DTI readings. A flat and parallel table will show no indicator movement.
If this condition does not exist, you can still perform a good tram. mount a piece of plate on the table and mill spots at 0, 90, 180, and 270 degrees from the spindle at the point at where the DTI would touch. For best results, don't change the height but mill a cross pattern. These four spots will now be at the same height. Now perform the tramming test.
Bob
