- Nov 27, 2012
- 7,863
I embarrassingly stand corrected. The power feed unit bolts to an L-shaped bracket that fastens to the end of the table with two bolts. This positions the drive gear over the driven gear on the leadscrew. There is also another L-bracket that bolts to the first L-bracket and also to the inside of the table edge. It is solid enough.
I do not see how you can adapt a four-hole attachment to the end of a RF mill, though. I don't think it will fit but then again, I haven't actually seen one done so maybe its possible.
Ah ok, mine is the same then. I was about to go buy an Align power feed! Well not really.
Agreed, I don't see how one could adapt a knee mill style power feed to be used in the vertical position on a mill/drill. Ours doesn't replace or mount to the leadscrew end bracket like they do on a knee mill. I'm sure it can be done but I still think it would be easier to just build one from scratch like others have.
