Revolver speed loader
Sorry I was late on delivery. Here are some of my Speed loaders. 0A4C8BE2-1FE8-4B15-896B-773F8CFADD6D.jpeg6345C366-8EA8-4AD8-8E14-E73B246DF7AE.jpeg
Not much of a notch is needed to retain the casing. Spring detent gives good engagements and roll pins are stops for movement.
I have a colt 45 that uses moon clips and only using acouple times I can say that moon clips load faster for me. The cylinder needs to be machined to accept though. 7C74DE0C-4830-4F01-B02E-558D01EEEF6C.jpeg
Thanks for the pictures. Yesterday I sprung a high pressure water leak in my shop, so I got the water all shutoff and a semi clean of my shop and just took the rest of the day off.
I think I've got all my measurements now and on those first two stems I'm all good for a 3rd go. I'll do the lathe work and put the stem in a dividing head, do the milling then just drill a hole for the detent shaft and spring and be pretty much done.
The roll pins look centered to the casing bores. So you get the correct throw. I saw you knurled the od on the shell holder. I love knurling but depending on the gun that knurling might touch the frame and scratch your finishes. Might want a recessed knurl instead.
So pontiac as the stem rotates it closes on the rim of the case to keep it in the loader. It looks like the portion that closed on the rim to hold it firm is slanted a bit. Is that slant on the top or bottom of the stem rim protrudence?
You can get a recessed knurl look by making nice deep knurls the usual way and then turn down the tops that stick up on your lathe.
