Reverse direction motor switching at it's most complex
o0norton0o
Dec 3, 2023
81
I should have started my own thread on this previously but I didn't. I hoped that I was missing something simple and it would be resolved simply, but instead, I learned that I couldn't get a simple answer to the complex wiring I was dealing with. The more I researched, the more I found my motor's wiring was not simple compared to most motor wiring schematics. I ended up needing a 20 pole switch to change spin direction and I used every terminal.
I thought about buying a new 1/3hp motor that might be easier to wire up the $15 amazon switch that I already had, but new motors were at least $160. going all the way to $300. if I wanted a certain brand. After bouncing my dilemma off of Mark in the other thread which I posted in, and following his link to a multipole switch, I realized that a switch similar to the one he suggest could do the job. I did my own pin diagram and came up with 20 poles to get every wire switched for both spin directions, and here's the result. Hopefully, it helps someone else who has the same complex wiring, or similar. The Baomain switch was $28. on amazon. It didn't come with an electrical box housing of any sort, so there's some extra work to be done.
I colored the Pin drawing in pink and black so the energized circuits would share the same colors when one or the other was switched on. The motor terminal side shows the "<" symbol which is a shared wire from each pair to the motor terminal. This works because only one wire in each pair is energized at a time depending on the switch position.
The motor is a Dayton 5k599a
The switch is a Baomain Universal Rotary Changeover Switch SZW26-63 660V 63A 3 Position 5 Phase SZW26-63/D505.5
Pictures below:
I wired this switch and motor with the load and line switched and it popped the circuit breaker. I thought about it a for a bit, then put my continuity tester on the electrical plug leads and got continuity in all switch positions which is no good. Then I realized that both incoming load and neutral just said, "Line" in the schematic, so I switched them because all the other contacts were correctly mapped. Once I switched the load and line, the continuity tester only showed continuity in the forward and reverse positions and no continuity in the off position. This was what I expected, so I tried plugging the motor in to test it. It runs in both directions as planned. It's a huge birdsnest of wiring, but it's working.
So, I'm set. My lathe now spins in both directions, has a draw bar style lock mechanism for the chuck when turning in reverse. I'll be able the thread now in either direction and also use reverse for backing up to make multiple passes when threading without turning the chuck backwards by hand.... like I did previously...:hate:
