- Apr 29, 2019
- 2,099
Single pointing is cutting the threads on a lathe. If you do not have a lathe.
IF the tie rod is hardened It may not weld real good. The frame uses structure to reduce the load on any one weld, This would be a simple but joint of likely dissimilar metals.
