- Sep 28, 2013
- 4,309
I think the problem too is that if you try to get better than the factory specs you've obtained you may end up chasing your tail, where one adjustment changes a value elsewhere, and fixing that one changings something else. I see it in building bicycle wheels - when the spoke tension gets high and the runout low, trying to reduce the runout in one place causes problems somewhere else. Whenever I see that start to happen I stop and call it good.
