- Oct 16, 2019
- 6,579
Ok if in neutral it runs fine through the full frequency range but will not when the spindle is engaged then to me it has to be related to the drivetrain that is in motion unless some parameter or issue in the VFD causes it motor to buck and stall like that.So in neutral the belts and motor run perfectly smooth at full speed. I checked the tension of the belt and it felt fine. Seems like if it was the belt being too loose I'd get some slippage even at low speeds when i'm turning something lets say aggressively and I've never had any issues with speeds 0-300.
@mksj have you ever seen a vfd powered motor do that?
