- Feb 7, 2013
- 2,490
It's starting to cool off significantly up here in northern Minnesota with temperatures in the 40s at night. The pipes in the boiler were
made of 1/8 inch wall schedule 40 pipe and the new pipes are going to be schedule 80, almost 1/4 inch thick. The first part of this
process is to cut into the water jacket to get to where the ends of the pipe are. After that one needs to use a hole saw (I used carbide.)
and a 4.5 inch angle grinder in preparation for welding in the pipes. The main difficulty is lack of space to work so two of us ran the
grinders for many hours to grind off old weld. This is a pressurized boiler so the welding job has to be good. The plan is to do a root
pass or two with 6011 rod using DC positive and finishing up with 7018.
The boiler has a fire in it still since I heat my house and shop with it as well as my domestic water. Here you can see a rectangular hole that
was cut with a plasma cutter to get to the pipes. You can see the three holes where the new pipes will be installed. I lowered the water level
in the boiler and just have a tiny fire just so I can take a shower and wash dishes. Also I hear the blower in the basement coming on in the night
to keep the house warm.
These are the new schedule 80 pipes to be installed hopefully today.
These are the old pipes, Two of them came out of the stove in two pieces!
I will make another post as this process continues. I'm not a professional welder by any means so hope it all goes back
together with no hitches. I will use the "whip and pause" method on the root pass.
