- Mar 20, 2014
- 418
My shop vac has a small diameter hose. As such, it tends to get clogged on a regular basis... So as we're all in lock down I've started noodling on Fusion 360 and came up with some new parts to allow me to fit a much bigger 50mm (2" near as dammit) to the Vac.
Not printed out as yet, as I'm waiting the post man to deliver the new hose for it - and I need that to measure the pitch and size of the reinforcing ribs that spiral down it. One thing I did find out is that an M68x5 thread (that's what the shop vac screw on connector is) is non standard - so I had to modify the thread files in fusion 360 to allow that size, according to the instructions here:
I shall update my progress as and when I print it out and get it all fitted.
Einhell Shop Vac - 50mm Hose Parts by GreatOldOne
Parts to replace the current 32mm sized hose and tools on my Einhell shop vac with a larger diameter (50mm) hose - I found I kept getting clogs in the hose vacuuming up chips and swarf from around my machine tools. All parts assume that the hose has an ID of 50mm and an OD of 60mm, as per this...
www.thingiverse.com
Creating custom threads and thread standards in Fusion 360 | Fusion 360 | Autodesk Knowledge Network
A nonstandard thread or a thread larger than a specific diameter is not available as a predefined thread type for Fusion 360. Is there an add-on or a way to create and use a custom/nonstandard thread? Is there a way to define an entire custom thread standard? Use a 3rd party add-on To create a...
knowledge.autodesk.com
