- Feb 27, 2014
- 2,131
Also make proprietary parts so they have to buy from you
or never buy from you again ...
The Electronic Lead Screw is what you are thinking about. Not full CNC but does tapers, threads, etc
Could just put on a simple stepper motor with a driver and a knob for speed control to conveniently adjust the speed of the axis. Pull off one gear to disengage the gear drive but also be able to replace the gear and do the gear change for threading. The stepper setup would free wheel when turned off so the lathe could work as normal too.
You would need to sense the position of the spindle for threading and could add that on with another control board later.
The plan would be to use a microcontroller to control the stepper and watch the spindle speed to maintain sync.
Cadillac STS,
That's what I'm doing with my project. I've taken it a step further in that I measure the spindle speed and calculate the proper stepper speed so the feed rate is calibrated in thous/Turn (between .001/T and .010/T).
