Removing Ford Y Block 292 External Oil Pump And Line To Oilpan
racecar builder
Dec 19, 2011
459
hobby machinist's
anybody know what i'm in for there?
starting at the front.
about the oil line, the big nut on the oilpan looks easy to loosen and
the flange nut at the oilpump looks like it's on there pretty tight.
we'll see!:)
have a nice day!
Ya that will come off, just make sure you have a good fitting wrench, and be
carefull with the O rings which are flat like a garden hose rubbers. In the past
they would tighten as over kill. This is the suction side. And check the three
rivits on the oil pan (pipe goes) they always weeped.
gk
i just remembered i did want to take off
timing cover next.
i guess it makes more sense to get external
oil line off, drop oil pan and THEN take the
timing cover off.
there's a couple oil pan bolts that
go up into timing cover.
have a nice day!
racing hobby machinist's
took another look at the situation yesterday.
that's 6 oilpan bolts going up into timing cover.
regarding the 'external oil line', i think IT IS the
pickup itself.
it goes THROUGH the oilpan and has a strainer on the end.
saw that on the net!:)
it looks like best thing to do is take oilpan and pickup off together.
will drain oil somehow with engine on ground, might get it up
on blocks or something.
will post some pic's of progress.
have a nice day!
hobby machinist's
this is gasping and sputtering along here.:)
the oil pump nut seems to be bigger than 7/8"
the biggest open end wrench i have around
at the moment.
tugged on the oilpan nut with big adjustable
wrench and seems like it's stuck pretty tight.
can't use pipe wrench's because of this
engine's 'Vintage' status.
don't feel like paying $40 for replacement parts!:)
i'll keep hacking away here!:)
have a nice day!
oil pump is off!:)
without breaking or bending anything.
whether you do this with oil pickup still in the way or not
it's best to TAKE OFF OIL PUMP COVER AND TAKE GEARS OUT FIRST!
to slide the oil pump back off of the pickup tube
you need the oil pump shaft out and
it helps to have the gears out.
have a nice day!
