- Apr 23, 2018
- 6,532
Replace the firing pin spring and see what happens. That 50 year old spring is surely tired and weak, so you might have ignition problems.
Load your cartridge for your chamber throat. 6mm (243) likes to be anywhere from .015 to -.005 at the lands. Factory ammo is short! Use a puller and re-sent factory loads to your gun. You will need a COL gauge and an ogive comparator ($40 per tool) to determine this, or you can candle smoke a dummy round with your bullet of choice, chamber it, and creep the length down until the rifling marks disappear. Measure overall length at tha point, and test from there.
Match the bullet weight to the rifle twist. Don't use 130 gr hunting bullets in a 11-twist barrel, that never works.
Chrono your shots. Otherwise you are guessing.
Crown condition matters, under certain conditions. Most folks take it seriously for good reason.
