- Nov 5, 2016
- 1,419
I visited an Amish machine shop that is close to me. A young guy I've bought V-belts and stuff from in the past. Good kid and always looking for machining tips. Anyways, last time I was there he offered me a DoAll bandsaw welder that originally came on his big saw. It had been removed before he bought the saw (from another Amish) and it was laying on his shop floor.
It was in pretty bad shape. Very dirty, loose wires everywhere, covered in grease and grime. The grinder motor base and been cut loose with a cutting torch. I was afraid it was 3-phase, but decided to take it home anyways, since it was free. Well, when I got it home, the grinder motor tag stated 220V 1-phase so I knew there was a chance. Did some searching on-line and found an electrical sketch that I thought might be close and went to work. Traced wires and started marking them, tore it apart and cleaned/polished the slide for the movable jaw. Fixed the grinder base, replaced some wiring and a lot of other fix-ups.
After putting it back together it welded great! So, I made up a box out of some 3/4" plywood scrap I had. Once I started welding some test blades I found that the jaws were in terrible shape and didn't even come close to holding the two ends of the blades square or in-line with each other. Tried to touch it up with a file, but no luck. So, on the mill I went and re-machined the jaws nice and straight.
I'm really happy with the way it turned out. Welds very straight and a good quality weld. I've welded 1/4" and 1/2" carbon steel blades and both seem strong and don't break when I bend them around by hand. Time will tell, but everything is looking great so far.
So, I put some time and effort into this project, but now I've got a nice bandsaw blade welder!
Ted
Ted
