- Feb 2, 2014
- 1,068
Brian thank you for the kind words but I do have an advantage. I try to design my engines in such a way as to use some parts I have already made for other engines for this engine. Take the cylinder head as an example. Except for some minor changes it is the same head as I have used on two other models. The timing gears and cam lobe is the same as three other engines I have built so it saves a lot of time.
Robert and frankly2 the top hat is mainly for cosmetic purposes. It will help to keep the water from splashing out and it does hide any mistakes I may have made when I milled out the water jacket.
But actually I just like it!
Lapped the valves and pressure tested them with shop air in a test plate.
Made the valve spring retainers and the intake valve spring from 0.010 music wire.
Thanks for looking
Ray
Thanks for looking
Ray
