- Mar 27, 2022
- 425
I need to address the slop on my loader. What steel should be used for the pins. This is my home use power wheel barrow essentially. Sometimes I work it hard but it doesn’t work often. I might have to increase the pin diameter, I don’t know how egg shape the holes are. The top cylinders are a weird design and I can cut out the middle of the pin section and replace.(see picture). Sorry I don’t have a good picture of it, it’s basically plate steel bent in to a c shape with a bushing welded between the ends. What metal would be recommended for that?
