- Feb 8, 2014
- 11,144
The wobble - how do I unscrew it out to check if it is cross threaded?
I did email the shop and this is what they said:
"The cog is at a slight angle on the spindle but the bore is in the centre of the cog so nothing to worry about."
That response from the shop sounds pretty lame. There is something not right with the way that is put together.
If you don't have a spanner wrench that will fit the nuts, a punch (or screwdriver) and a hammer will do. ( I know I am going to catch hell for saying that) Not sure if those are left or right hand threads, so if it doesn't loosen in one direction, try the other.
EDIT: I looked at the video again, those are right hand threads in the spindle nuts. Be careful not to damage the speed sensor hardware. You will probably have to remove the speed sensor to get the wheel out.
