- Oct 31, 2016
- 2,645
I made a stout barrel vice and aluminum inserts. It is attached to one of my work benches. I don't have a hydraulic press. If I did I would use it like your set up. I have a 6' piece of 2x1.5 angle that came from a bed frame for the cheater. I don't know what kind of steel it is. It is so hard that a drill just rubs. An end mill will cut it. In another thread discussing spot annealing it was mentioned to use a nail in a drill press pressed hard against the material until it glowed from the heat. It would soften the metal so you could drill it. I will give that a try. Be interesting to see the result. Could be BS. No loss if I ruin a framing nail in the process.
Thanks for sharing your knowledge.
