- Nov 25, 2015
- 8,298
Did you mean tapered reamer?Using a tapered reamer it a lot more hassle, and slower.
In my limited knowledge, you really can't avoid a tapered reamer unless you use a tapered drill bit. After rebuilding the SB 9, I started to appreciate tapered pins over straight pins. They lock in there really nicely. So I bought a set on ebay used. Of random sizes hoping to wind up with what I wanted. I did, and then some.
I agree that they are a hassle to use. The hole size is tough. I try to drill 3 holes, a small pilot for the smallest size, and then I try to go a little larger for the mid section, and larger still for the largest section, then I try to blend them together using the tapered reamer. Mostly I succeed. Sometimes I have run into issues that I have yet to figure out what happened, what I did wrong. Those times I hope that the next size taper pin will cover up the Fup. But usually we are dealing with limited sizes to use based no the part size.
