- Feb 1, 2015
- 9,621
Old screwdrivers can be reground to make awls, ice picks, and scribes as well. Cut the blade to the desired length and grind, chilling frequently in water to prevent drawing the temper. If you do draw the temper, the blade can be rehardened by heating with a torch to a red-orange (until it loses magnetism) and then quenched. Polish the tip and heat slowly to a dark straw color to temper. If you bend the point into a hook while at a red heat, it will make an excellent cotter key puller.
