Re-learning how to sharpen twist drills
markba633csi
Mark Silva
Apr 30, 2015
11,340
My shop teacher could do a fair job of drill hand-sharpening but I never had much luck doing it.
Recently, I needed to make a drill extension so I wanted to use a "junk" drill; I needed to put a new edge on it.
I found a tutorial on YouTube by a guy named Tom, he uses a two-step method first grinding the edge angle and then doing the relief afterwards, all freehand, but using a protractor to measure the angle.
I watched carefully and tried it- success! Tested the drilled hole and it was only .001" over the shank diameter. And I just eyeballed the angle and relief- pretty good for a first try.
Mark S.
Interesting, can you link to the YouTube video?
Dave H. (the other one)
Sharpening a drill by hand is a black art... Not really, but it is something that you get better at with practice.
agreed, it took me about 2 inches until I finally sharpened my first drill bit correctly. i'm still not that great at it, but practice does help a lot. be patient.
i started doing this back in my mid teens, couldn't afford new drills, no neighbors knew how, had to figure it out my self,now 40 years later i can do it great,best to learn on big drills that way u can see what u are doing,, u can sharpen end mills too for ruffing,just radius the corners, or the sharp edges will dull too soon.
Not bragging but...I've successfully sharpened drills as small as .038, not every time, but enough that I keep trying. It's just a matter of feel at that size.
Here is the link (I think) to Toms Techniques the YouTube tutorial I watched...
https://www.youtube.com/watch?v=y0SQkzScQk0
Mark S.
Thanks, I'll have a watch later!
