- Dec 18, 2019
- 6,593
I've seen some plastic gear sets for slowing down the feed rate of mini-lathes for sale. They aren't too expensive, but they seem to be 3D printed, which makes me feel uncomfortable. So I am thinking about making as set myself. Down the rabbit hole I go.
So I spent a little time reading about gears. Found and downloaded some of the resources here on HM, and in this sub-forum. LMS says the module as 1, so it's metric. No surprise there. The gear set is 80/15 and 90. I can calculate the blank sizes. At some point, I will figure out the pitch angle. It's probably 20 degrees, but I'll check.
What I am confused about is when I go to eBay and look for involute cutters, they sell sets of M1 cutters. Then there are sizes of #1-8. What are these sizes? Can someone explain this?
Could I make these gears using my PM25? I probably would make the gears out of steel. What "stuff" would I need to do this? An indexing head with dividing plate, and ? Obviously, I'd have to make the arbor for the cutters, and something (an expanding mandrel?) to hold the gear blank. As you can tell, I'm in over my head, but I am intrigued with the idea of making gears. Gears have always fascinated me.
Anyways, are there resources for the dummy's guide to cutting gears?
