R8 Arbor With Jacobs Taper
kingmt01
Apr 29, 2015
899
I have
It came with a R8 arbor with a Jacobs taper.
Does anyone know what size that taper would be?
I tried to put a j33 chuck on it but it is bigger then the arbor.
Those are the only two places it is touching on the very end.
Measure the taper of the arbor at the small and large ends and the distance between those measurements and report back.
That is looking awfully straight to me... A #3 which is common would have a ~.060" diff.
How long in the taper in your hand?
Lose the cool tools as the background, and shoot it against a straight edge and a contrasting background. :grin:
Big end is .618" small end is about .585" I don't have a good way of measuring taper. It is about 3/4" between those measurements.
That is what I was thinking. I suck at trig to figure out the size at .775" tho.
Are you sure that chuck doesn't have a JT3 taper?
Even if we were to trig it out, there is still the fact that the bluing is messed up...
Any number on the chuck?
